[AG-TECH] Re: Display Machine Performance
Robert Olson
olson at mcs.anl.gov
Fri Mar 15 10:46:39 CST 2002
At 10:39 AM 3/15/2002 -0600, Art Ziarko wrote:
>I have spoken the Gentner tech support about apware in the past. They said
>the software will use less processor power if other applications need it. So
>in effect it auto adjusts the processing power that it takes up
However, if the video is not reacting well with the gentner software
running, it is apparently not doing it right. (I had the same interaction
with their tech support awhile ago ..)
Chris - you're running on a uniprocessor system, right? If so, the APserve
is competing directly with the vic for the processor; on a dual-cpu system
it probably handles the load better..
--bob
