[AG-TECH] FYI: Adapting Windows 2000 TCP/IP stack to high bandwidth connections
Jay Beavers
jbeavers at microsoft.com
Wed Mar 6 15:38:55 CST 2002
Per a discussion at the Access Grid Retreat, below are the registry
changes I use to optimize the TCP/IP stack of Windows 2000 for DSL line
or higher connectivity. I found them at:
http://www.speedguide.net/Cable_modems/cable_reg_win2k.shtml
This isn't a 'definitive' guide, this is just a file I pulled off the
Internet. If you want detail on what this is doing, I'd refer you to a
whitepaper on the Windows 2000 TCP/IP implementation, found at:
http://www.microsoft.com/windows2000/techinfo/howitworks/communications/
networkbasics/tcpip_implement.asp
- jcb
--- Cut here, put into a file ending in .reg, double-click and you're
good ---
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"SackOpts"=dword:00000001
"TcpWindowSize"=dword:0003ebc0
"Tcp1323Opts"=dword:00000001
"DefaultTTL"=dword:00000040
"EnablePMTUBHDetect"=dword:00000000
"EnablePMTUDiscovery"=dword:00000001
"GlobalMaxTcpWindowSize"=dword:0003ebc0
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020306/87cf913b/attachment-0001.htm>
