[AG-TECH] Venue Server Installation
    Don Morton
    morton at cs.umt.edu
    Fri Mar 22 16:03:53 CST 2002
It's a very small node - 100MHz Pentium, 128M RAM, Jeremy can
fill you in on the disc space, which I think is sorta sparse.
We'll help in any capacity that we're able :)
But, he did just create a MooseDrool room and the two of
us need to figure out how to go about getting multicast
addresses associated with this, and neither of us have
a clue.
Michael/Bill - you can expect to hear from me :) :)
Plus, Jeremy and I will go through some of the old list
archives that "seem" to address some of these issues?
If someone has a quick "cookbook" method on how to get
Class D addresses associated with this vv server, we'd
be appreciative.
Jeremy did a great job (I'm half way out of town now,
Jeremy!! :) :))!!
Lisa Childers wrote:
> Will you folks be able to use this node as a testing node, on which you
> would install early software?  I am in the midst of trying to build an ag
> testbed and trying to line up nodes for that can participate in this kind of
> testing.
> Lisa
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Don Morton
> Sent: Friday, March 22, 2002 3:28 PM
> To: Jeremy Sauer
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Venue Server Installation
> Hello All,
> I JUST finished typing the following problem report,
> and Jeremy came running to my office to tell me he
> fixed the problem.  Our system administrator suggested
> he disable ipchains, and, now we can get into our
> vv server.  I haven't played much with ipchains but,
> I'm sure it could be configured with "some" effort
> such that it didn't need to be disabled but, I'm
> simply sending this report to the list so that others
> are aware of the potential ipchains roadblock.  At
> this point in time, it's just an experimental server,
> and it seems to have other security measures implemented,
> so I'm not real worried (though I did "XXXXXX" out the
> hostname in the following description lest some of
> you get a little "adventuresome" :) :) :)).
> But I AM worried that I'm not going to have the time
> to climb as high into the mountains as I had planned :(
> Don
> All,
> Here are some relevant details on Jeremy's problem.
> I "could" spend the afternoon and possibly resolve these
> myself but I REALLY want to go out skiing at Lolo Pass
> and the afternoon is already growing short :) :)
> So, I told Jeremy, after explaining the "first level"
> problem to him, that I'd post this to the list, then
> let him deal with responses while I head up into the
> backcountry :)
> Essentially, "default" security is set up on the venue
> server such that one can't telnet
> to any of the ports from an outside machine.
> For example:
> telnet XXXXXX.cs.umt.edu 80
> yields a response of connection refused.  Yet, when doing
> the same thing FROM XXXXXX.cs.umt.edu, the connection
> accepts commands.  So, clearly, the httpd IS accepting
> requests but, apparently only from the localhost.
> Likewise, same deal with sshd - one can telnet to port
> 22 locally, and the localhost accepts the command but,
> when trying to telnet from the outside
> telnet XXXXXX.cs.umt.edu 22
> connection is refused.
> In the old days, I'd muck around with hosts.allow,
> hosts.deny, inetd.conf and could usually get something
> working but, I'm not sure how these new Redhat defaults
> are set up.
> So, it looks to me like Jeremy's first step is to understand
> what needs to be configured on the localhost that will
> ultimately allow it to accept remote requests on port
> 80 (httpd) and others, such as 22 (sshd).
> Jeremy Sauer wrote:
> > Hi all,
> >     After following instructions in various archived ag-tech e-mails and
> > other documentation, I was able to successfully run the vv-configure
> > script. I needed to install a couple rpms that weren't listed but
> > eventually dependecies seemed to be resolved.  However, after running
> > the script and obtaining a wizard password,  I could not visit the
> > server via a browser from another machine.  I am sure that I have
> > installed the apache rpm.  I am able to ping the server machine but
> > whenever I try to visit the server via a browser I get no response.  I
> > am pretty new to the Linux world so I may be missing something that
> > would be obvious to someone with any experience.  Does anyone have any
> > suggestions on things I can do to identify the problem, and then fix it?
> > Thanks,
> > Jeremy Sauer
> > University of Montana
> > Node-Operator
>    Don Morton                   http://MRoCCS.cs.umt.edu/~morton/
>    Department of Computer Science       The University of Montana
>    Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
