[AG-TECH] APware running - always or just when needed
Jonathan C. Humfrey
jch at cs.ucsb.edu
Mon Mar 18 12:26:09 CST 2002
Thanks Bob, I think we might be. What is the best way to set up the AEC
reference?
Jonathan
On Mon, 18 Mar 2002, Robert Olson wrote:
> At 09:33 AM 3/18/2002 -0800, Jonathan C. Humfrey wrote:
> >We have been experiencing serious wierdness in our XAP 800 where both
> >speakers will be producing very poor quality, static filled sound which is
> >totally unusable. At that point if we mute one of the two speakers (it
> >changes each time) the other will work well by itself. Eventually that
> >speaker goes out, we need to mute it and the other comes back on. Could
> >this have anything to do with the fact that we are running AP Ware all the
> >time? Does anyone have any knowledge of a problem like this?
> Hm, weird. You might doublecheck the gentner matrix to make sure you are
> not routing a microphone in put to the output being used as the echo
> cancellation reference (this can cause some weird effects). You can
> sometimes tell if this is the case if you tap on the microphone and you
> hear the tapping on the local speakers - if you haven't configured
> explicitly for local reinforcement, you shouldn't hear the local audio back.
> If there isn't a matrix setting that looks like it'd cause the problem, but
> you hear the tapping, your PC card mixer may be looping back. If you have a
> late-model SB PCI128 or other AC97-compliant card, try this:
> aumix -l 0
> and see if it helps. If it does, (assuming you're running the opensound.com
> drivers), you can run
> /usr/lib/oss/savemixer
> to save the settings for the next reboot.
> --bob
