[AG-TECH] VNC stability problems?
Michael Grobe
grobe at raven.cc.ku.edu
Fri Mar 15 16:51:54 CST 2002
tom:
> from the site:
> "The Windows version of the VNC server does not appear to allow multiple
> clients, so this approach cannot be used to display PowerPoint slides or
> other Windows applications running on the Podium laptop."
> This is odd, we are able to connect multiple
> sites to a pc server here and are not experiencing the
> crashing either.
at the time we wrote this sentence it was true....in that it so "appeared"
to us :=)
and perhaps it WAS true under some setting configurations, but i'm not sure.
however, i learned a couple of months ago that the Windows version of
VNC can, connect to multiple clients, but had not yet fixed the doc.
i have now changed a version of the doc at
http://www.cc.ku.edu/~grid/docs/access-grid-node/vnc/
to correct this problem, and have submitted a request to change the
document at:
http://www.ku.edu/acs/docs/access-grid-node/vnc/
sorry for the inconvenience.
:michael grobe
> At 07:50 AM 3/15/2002 -0600, Robert Olson wrote:
> >We've found in the past that the Windows VNC server is not nearly as
> stable
> >as the Unix server..
> >The Kansas folks have put together a note about using a Unix VNC as a
> relay
> >for the Windows one:
> >--bob
> >At 08:35 AM 3/15/2002 -0500, bernholdtde at ornl.gov wrote:
> >>Trying to use VNC during an AG session yesterday, I experienced rather
> >>severe stability problems. When I first connected (as a client), it
> >>stayed up for probably 10-15 min. Then is died without any warning or
> >>messages, and from that point, I wasn't able to get it to stay up for
> >>more than about 30 seconds, trying perhaps half a dozen times over the
> >>subsequent three hours. I think ANL might have experienced similar
> >>problems, but no one else on the session was running VNC.
> >>The servers was on a Windows laptop at NCAR, and it didn't seem to
> >>have a problem -- the user saw no evidence of any thing, and I was
> >>able to connect at any time I tried.
> >>We used the VNC client last week for another session, and it was fine
> >>for at least an hour. The server was a unix box at LBL.
> >>Has anyone experienced this? Its a little hard to debug when there is
> >>no indication of any kind what happened.
> >>Thanks
> >>David E. Bernholdt | Email: bernholdtde at ornl.gov
> >>Oak Ridge National Laboratory | Phone: +1 (865) 574 3147
> >>http://www.csm.ornl.gov/~bernhold/ | Fax: +1 (865) 574 0680
> ___________________________________________________________
> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
