[AG-TECH] Re: Display Machine Performance
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Fri Mar 15 11:18:44 CST 2002
>At 10:39 AM 3/15/2002 -0600, Art Ziarko wrote:
>>I have spoken the Gentner tech support about apware in the past. They said
>>the software will use less processor power if other applications need it.
>So
>>in effect it auto adjusts the processing power that it takes up
>However, if the video is not reacting well with the gentner software
>running, it is apparently not doing it right. (I had the same interaction
>with their tech support awhile ago ..)
>Chris - you're running on a uniprocessor system, right? If so, the APserve
>is competing directly with the vic for the processor; on a dual-cpu system
>it probably handles the load better..
Yup - single processor. Up till now no problem.
Thanks to Art and Bob for relaying Gentner's replies. To my
simple way of thinking a process that is driving a single serial
port at 9600 baud shouldn't be written in a way that hits another
process that is handling 10s of Mbits/sec of video data quite
happily, single processor or dual processor. I'll get back to them
myself and see whether there's a workaround.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
