[AG-TECH] Recording and Playback software
Ivan R. Judson
judson at mcs.anl.gov
Wed Jun 26 19:58:26 CDT 2002
Steve,
I'd be happy to work with you on adding this functionality to our
Voyager Multimedia Server (http://www.mcs.anl.gov/fl/research/voyager).
It's a recording and playback server that currently serves not only the
AG but other purposes as well.
If you are interested drop me a line and let's see if we can figure out
how this would fit. I have some ideas that might help you.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Steve Cutchin
> Sent: Wednesday, June 26, 2002 4:54 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Recording and Playback software
> Does anyone have any good recording and playback software for
> the Access Grid?
> Right now I have tools that capture and record the audio and
> video into RTP files. That is working quite well.
> Then I have Java Media Frameworks based tools that let you
> play back the video and audio like in a VCR. It also reads
> the time stamps and tries to align streams based on time
> codes. This is a little shaky right now. Plus I seem to be
> getting drift in the RTP timestamp within the RTP streams
> because over time the audio and video drift out of synch.
> The difference is small as drift does not become noticeable
> until after an hour.
> In addition I can convert the saved RTP video to quicktime
> files which I can then combine with the audio as well. These
> are a bit big; an hour long session of one camera in
> quicktime is about 500Megabytes.
> However my Java editor is not as good as I would like,
> I can't do annotating, cut and paste, etc, etc on the
> files.
> So before I write that into it I thought I would check to
> see if anyone has any video manipulation tools that will
> work on RTP streams or files? I can always use adobe
> premiere for the quicktime stuff but I have to make
> something that works directly on the RTP data for a project.
> Any help would be appreciated.
> Steve C.
