[AG-TECH] Virtual Venues Server Software
    Gregory Goddard
    ggoddard at ufl.edu
    Thu Jun  6 13:53:36 CDT 2002
This is a RedHat 7.3 system with postgresql 7.2.1. -g
On Thu, 6 Jun 2002, Robert Olson wrote:
> Which OS & postgres version are you running? there were some changes
> between rh7.1 and 7.2 that I've not been able to add to the distribution
> yet. my current recommendation is to try building on a rh7.1 system.
> --bob
>   At 01:52 PM 6/6/2002 -0400, Gregory Goddard wrote:
> >Bob,
> >The problem I am currently having is:
> >[root at ag-venues bin]# ./vv-configure
> >Initialize mud...
> >Initialize database...
> >DBI->connect(dbname=template1) failed: FATAL 1:  IDENT authentication
> >failed for user "postgres" at /usr/local/ag/VVServer/lib/DBSetup.pm line
> >74
> >Could not connect to database as user postgres
> >db setup failed
> >I can send you /tmp/vv-config.log in a separate email if you wish.
> >-g
> >On Tue, 15 Jan 2002, Robert Olson wrote:
> > > At 03:55 PM 1/15/2002 +0100, Luc Renambot wrote:
> > > >I played with it some time ago, but got stuck somewhere
> > > >with authorization problems related to "postgresql"
> > > >(which I don't know, I know more mysql) when creating
> > > >new rooms.
> > > Please let me know when you run into problems like this so that I can
> > fix them.
> > > >The problem of the IP addresses came in also. Can I used
> > > >addresses given by SDR when creating a session ?
> > > Yes.
> > > --bob
