[AG-TECH] Virtual Venues Server Software
    Robert Olson
    olson at mcs.anl.gov
    Thu Jun  6 13:45:00 CDT 2002
Which OS & postgres version are you running? there were some changes
between rh7.1 and 7.2 that I've not been able to add to the distribution
yet. my current recommendation is to try building on a rh7.1 system.
--bob
  At 01:52 PM 6/6/2002 -0400, Gregory Goddard wrote:
>Bob,
>The problem I am currently having is:
>[root at ag-venues bin]# ./vv-configure
>Initialize mud...
>Initialize database...
>DBI->connect(dbname=template1) failed: FATAL 1:  IDENT authentication
>failed for user "postgres" at /usr/local/ag/VVServer/lib/DBSetup.pm line
>74
>Could not connect to database as user postgres
>db setup failed
>I can send you /tmp/vv-config.log in a separate email if you wish.
>-g
>On Tue, 15 Jan 2002, Robert Olson wrote:
> > At 03:55 PM 1/15/2002 +0100, Luc Renambot wrote:
> > >I played with it some time ago, but got stuck somewhere
> > >with authorization problems related to "postgresql"
> > >(which I don't know, I know more mysql) when creating
> > >new rooms.
> > Please let me know when you run into problems like this so that I can
> fix them.
> > >The problem of the IP addresses came in also. Can I used
> > >addresses given by SDR when creating a session ?
> > Yes.
> > --bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020606/2184d628/attachment.htm>
