[AG-TECH] A video problem
kevin dong
kevindong at sdb.ac.cn
Mon Jun 24 04:08:06 CDT 2002
hi Christoph,
I have completed the total configrations on the computers and configure the vic software with the .vic.tcl file you offered. But to my surprise, the output video I see is still in NTSC model though the menu window appears that the input signal is pal. So I must choice the pal mode manually. Do you know what the problem is?
Thank you for you help.
kevin
======= 2002-06-12 10:08:00 you wrote:=======
>Kevin,
>Below is a script that we use to initialise preferred settings for our
>vic sessions. It should be named ".vic.tcl" and placed in the user's
>home directory (we have a generic access grid user login named "ag" so
>this script becomes /home/ag/.vic.tcl). You should change the script to
>reflect the exact settings you require.
>Note that we used a vic which we compiled ourselves from the UCL source
>code (version 4.2.4) but I presume that this technique will work with
>the "official" ANL version too.
>chris
>On Tue, 2002-06-11 at 15:26, kevin dong wrote:
>> Every time when I open the video capture, the signal type in the video infomation box is set to NTSC ,not PAL. How can I initialize the signal type to PAL??
>> Looking forward to any help.
>> kevin dong
>> 2002-06-11
>> Database Dept.
>> Computer Network Info Center,China Academy of Sciences
>> Tel: 0086-10-62580066
>> Fax: 0086-10-62578544
>> Email:kevin_dong2000 at yahoo.com,kevindong at sdb.ac.cn
># vic startup script .vic.tcl
>option add Vic.maxbw 3072 50
>option add Vic.bandwidth 3072 50
>option add Vic.framerate 16 50
>option add Vic.quality 85 75
>option add Vic.rtpName " AG Sydney"
>option add Vic.defaultTTL 32
># The procedure named 'user_hook' is called when vic starts up;
># this version of the procedure starts transmission.
>proc user_hook {} {
> global inputPort inputType fps videoDevice videoDeviceList
> after 200 {
> toggle_window .menu
> set inputPort Composite1
> .menu.cb.frame.right.fps.scale set 24
> set inputType pal
> set brightness 110
> set contrast 110
> set note [option get . note Vic]
> if { $note != "" } {
> update_note "" $note
> } else {
> switch $videoDevice {
> "_o3" {
> update_note "" "PRESENTER (ATP)"
> "_o2" {
> update_note "" "AUDIENCE (ATP)"
> "_o1" {
> update_note "" "MAIN (ATP)"
> default {
> update_note "" "Vislab (ATP)"
> $transmitButton invoke
> toggle_window .menu
># end of script
kevin dong
2002-06-24
Database Dept.
