[AG-TECH] PIG Questions
Allan Spale
aspale at evl.uic.edu
Tue Jul 9 13:10:23 CDT 2002
Edit the video-config file. It is an XML file. I tried deleting one of
the <capture_card> rows since the EVL nodelet has the same case, and I was
able to only have one capture card recognized.
However, I had trouble getting PIG to work properly. Everything ran
properly, but the video it displayed had a bluish tint. Instead of
dealing with figuring out why that did not work, I did a "creative
workaround" and got PIG to work in a different way.
Good luck.
Allan
EVL at UIC
node-op
On Tue, 9 Jul 2002, Cindy Sievers wrote:
> We are trying to get just one hauppage card to work, but aren't having much
> luck.....is the PIG set up to only use osprey drivers?
> At 10:23 AM 7/8/2002, Thomas M. Mueller wrote:
> >we've tried to use the hauppauge cards in the past, and unfortunately we
> >could never get more than one of them to work at the same time under
> >windows. the osprey cards do this without a problem. i remember
> >someone mentioning that they use the same chip so theoretically there
> >might be a way to get the osprey drivers to work with the hauppauge
> >cards, but i haven't had any success with this.
> >On Mon, 2002-07-08 at 12:19, Allan Spale wrote:
> > > Hello,
> > > I had some questions about the PIG software. First, are the Hauppauge
> > > video cards supported? Second, if I wanted to configure PIG for this
> > > video capture card, what steps should I take?
> > > Thanks for your assistance.
> > > Allan
> > > EVL at UIC
> > > node-op
> Cindy Sievers Los Alamos National Laboratory
> sievers at lanl.gov Group CCS-1 MS B287
> tel:505.665.6602 Advanced Computing
> fax:505.665.4939 Los Alamos, NM 87544
