[AG-TECH] AG Projector options?
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Thu Jul 18 06:05:23 CDT 2002
I'd second the comments about heat, but don't find automation
an issue.
An issue that seems to be becoming more important for us is
resolution. We have a 'standard' rig of 3 1024x768 projectors.
As soon as we start a VNC session and maybe a whiteboard or
equivalent - for a shared visualization meeting - we are clean
out of 'pixel space'. The VNC session tends to take up a
complete projector's worth, and we sometimes run two such sessions.
'Medium' video feeds require 40% width and height of a 1024x768
image. I haven't done the calculation
but I guess the total size for a Medium image is about 400 wide
by 320 deep (384x288 plus margins and title). While I allow these
to span projector images, it is generally neater not to.
3 1024x768 projectors give you 3072 x 768 pixels = 2.36 Mpixels
3 1280x1024 projectors give you 3840 x 1024 pixels = 3.93 Mpixels,
a 66% increase
With the 1280x1024 size, you can easily get 9 medium video
feeds (3x3 array) on each projector, so 27 Mediums total.
While we don't have funds to replace our projectors at present,
and I haven't had time to investigate which cards will drive
3 1280x1024 outputs, if we were buying now I'd be looking at
this. We even have difficulty with a regular 10 / 11 site
meeting fitting the 20 - 25 video feeds onto the wall.
We run with about 8 Mediums and the rest Smalls.
We have to resize most of them to Small size when a DPPT
presentation is on.
HTH
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Markus Buchhorn [mailto:Markus.Buchhorn at anu.edu.au]
Sent: 18 July 2002 02:08
To: ag-tech at mcs.anl.gov
Cc: drew.whitehouse at anu.edu.au; Peter Young; hugh.fisher at anu.edu.au;
david.walsh at anu.edu.au; rod.harris at anu.edu.au; Markus Buchhorn
Subject: [AG-TECH] AG Projector options?
Hi All
The ANU is now looking at placing orders for its Access Grid nodes. Scanning
back over the ag-tech archives I've seen lots of discussion on PCs, audio
and video cards, Gentners, etc. but not on projectors - barring a very brief
thread about 2 years ago.
Times have changed. I'd be interested to know what people are using for
projectors (or rejected), and what features they found they like/need/hate,
and how important they'd rate them? I'm not a projector/visualisation geek,
so need some guidance :-)
I know some sites are using active plasma screens instead of projected
screens - any comments on those?
Just off the top of my head:
- resolution: 1024x768 minimum, 1280x1024 better (real, not interpolated)
- brightness: the more lumens the better
- inputs: (besides VGA cable) composite? component? (analogue, digital?)
- keystone correction: optical not electronic? (quality)
- zoom, focus: manual not electronic? (cost)
- remote control: are there any with serial ports instead of an IR remote?
- lens options: ability to do ~1:1 (short throw -> large display area) or
better?
- frame rate: 60-70Hz is common. 100-120Hz for active stereo projection
- filter options: various polarisation filters for passive stereo
projection
- colour correction options: Handling different light-bulbs' effective
temperatures, to give a natural reproduction (of whatever has been captured
- a separate issue).
- image flip: floor vs roof mounting, front vs back projection
- oh yeah: COST :-) (start up capital, consumable bulbs)
What other features are worth looking for (good or bad)? I've also seen
people comment on the various internals of different projectors - some
appear to have better colour correction features, or better optics, or use
analogue or digital signals within the box, or ... ?
Quality of TV/AV reproduction is probably also a feature, where nodes are
also used for viewing major sporting events :-)
I'm happy to collate responses and generate an AGDP document if desired -
there isn't anything there now beyond a very basic para or two. Please feel
free to email me directly, and/or the list, as you see fit. I can anonymise
the results if you really want to bitch about something :-)
Thanks for any comments you can offer!
Cheers,
Markus
Markus Buchhorn, ANU Internet Futures Project, | Ph: +61 2 61258810
Markus.Buchhorn at anu.edu.au, mail: Bldg #108 - CS&IT |Fax: +61 2 61259805
Australian National University, Canberra 0200, Aust. |Mobile: 0417 281429
