[AG-TECH] Unicast-Multicast bridges?
Randy Groves
randy.groves at boeing.com
Tue Jan 22 09:36:29 CST 2002
We have multicast within Boeing, but not, as far as I know, between Boeing
and the real world. I'm interested in bridging facilities for possible
support of areas in Boeing that are not yet set up with multicast.
Thanks! I'll take a look.
-randy
At 09:05 PM 1/21/2002 -0600, Stuart Levy wrote:
>I have a simple one at
> http://niri.ncsa.uiuc.edu/tools/udpbridge.tar.gz
>You specify the port-pairs that it should forward on.
>And there's no security (though there's a code stub for
>an access list). Anyone who sends a unicast packet, at least
>one per two minutes, to the bridge on either port of a port-pair
>will get all traffic on that port-pair.
>One bridge can forward several port-pairs. E.g.
> udpbridge -p 8666 224.3.175.111/8666/24 -p 6822 224.117.3.51/6822/32
>The "-p NNNN" listens on that odd-even unicast port pair, and
>mcastaddr/port/ttl does likewise for that multicast address/port-pair.
>It would need to run on a machine that had multicast access;
>is it true that you don't (or won't) have that anywhere in Boeing?
>It'd also need to run on a machine that wasn't using any of those
>ports for other applications, so it couldn't be on an AG machine itself.
>And, I've never used this in the high-traffic AG environment;
>it doesn't seem to take any noticeable CPU time when forwarding 100-odd
>packets per second (~1% CPU at 50 pps input, 150 output), but
>your mileage may well vary...
> Stuart
