[AG-TECH] Unicast-Multicast bridges?
Stuart Levy
slevy at ncsa.uiuc.edu
Mon Jan 21 21:05:57 CST 2002
I have a simple one at
http://niri.ncsa.uiuc.edu/tools/udpbridge.tar.gz
You specify the port-pairs that it should forward on.
And there's no security (though there's a code stub for
an access list). Anyone who sends a unicast packet, at least
one per two minutes, to the bridge on either port of a port-pair
will get all traffic on that port-pair.
One bridge can forward several port-pairs. E.g.
udpbridge -p 8666 224.3.175.111/8666/24 -p 6822 224.117.3.51/6822/32
The "-p NNNN" listens on that odd-even unicast port pair, and
mcastaddr/port/ttl does likewise for that multicast address/port-pair.
It would need to run on a machine that had multicast access;
is it true that you don't (or won't) have that anywhere in Boeing?
It'd also need to run on a machine that wasn't using any of those
ports for other applications, so it couldn't be on an AG machine itself.
And, I've never used this in the high-traffic AG environment;
it doesn't seem to take any noticeable CPU time when forwarding 100-odd
packets per second (~1% CPU at 50 pps input, 150 output), but
your mileage may well vary...
Stuart
