[AG-TECH] RAT line-in swap
Jeff Carpenter jeffc at ncsa.uiuc.edu
Tue Feb 19 13:40:17 CST 2002
Not sure if it will fix your problem, but you might try setting all of your
options, then pressing "quit" on the lower right.  This seems to set the
defaults, at least in some versions of RAT.
Cheers,
Jeff
__________________
At 07:06 PM 2/19/2002 +0000, andrea jackson wrote:
>During our test cruise today I had problems with the RAT 'line-in' option
>automatically switching to 'microphone', thus disabling our outgoing audio
>mid-session (I'm sure as can be that it was not a slip of the finger when
>muting the Talk option above it) This happened twice and I had to reset it
>manually. It was not too disruptive the second time, as I had discovered
>what to look for, and the solution was simple and speedy - just click on
>'microphone'  to scroll back to 'line-in'.
>Does anyone know why this happens and if there is anything I can do to
>prevent it happening again?
>Thanks,
>Andrea
>Andrea Jackson
>Manchester Computing
>+44 (0)161 275 6090
>videoconference at man.ac.uk
>accessgrid at man.ac.uk
>wwopers at deprecate.mcc.ac.uk
More information about the ag-tech mailing list
