[AG-TECH] projector/room setup
Ulrich Schwenn
schwenn at rzg.mpg.de
Fri Dec 20 01:48:57 CST 2002
to be exact it is +/-85% vertical and +/-55 horizontal...
Ulrich Schwenn wrote:
> There is a little help if you consider one of the NEC beamers namely
> the the GT950, which allows an optical lensshift of +/-55%, bringing
> the beamer quite a lot out of sight even for low videowalls.
> Sinc
> Ulli
> Osland, CD (Chris) wrote:
>>> The more I read about keystoning and throw distances the more
>>> trouble I am having trying to figure out how to do it.
>> To get a 5' high videowall, with the centre of the wall at the
>> height of an adult's eyes when seated, without the projector
>> being so low it was regarded as a safety hazard, I use a
>> projection screen (21' x 6') on a frame which I rest against
>> the wall with the base of the frame toed out from the wall.
>> The screen is perforated and the (4) speakers are ranged along
>> the wall behind the screen.
>> Cheers
>> Chris
>> ____________________________________________________________________
>> Chris Osland Office tel: +44 (0) 1235 446565
>> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
>> BIT Department Access Grid room tel: +44 (0) 1235 445666
>> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
>> CLRC Rutherford Appleton Laboratory (Bldg. R18)
>> Chilton, DIDCOT, Oxon OX11 0QX, UK
>> [The contents of this email are confidential and are for the use of
>> the intended recipient only.
>> If you are not the intended recipient do not take any action on it or
>> show it to anyone else,
>> but return this email to the sender and delete your copy of it.]
*Dr. Ulrich Schwenn *
Head of Multimedia and Videoconferencing Group
Computing Center Garching
Max-Planck-Gesellschaft &
Max-Planck-Institut für Plasmaphysik
Boltzmannstr. 2
D-85748 Garching, GERMANY
Phone: +49 89 3299 1371
Fax: +49 89 3299 1301
Mobile: +491715072182
e-mail: schwenn at rzg.mpg.de <mailto:schwenn at rzg.mpg.de>
web: http://www.rzg.mpg.de <http://www.rzg.mpg.de/>
