[AG-TECH] PIG question
Justin Binns
binns at mcs.anl.gov
Mon Dec 16 10:40:55 CST 2002
The easiest way to find these names (currently) is to run vic from the
command line and look in the drop-down box of devices (in the capture
menu). Copy the text exactly (case-sensitive) as a device name in the
video-config file. For USB cameras and the like, it's almost certainly
the WDM to VfW mapper that you're interested in, so the device name should
be (possbly exactly) 'Microsoft WDM Image Capture (Win32)'.
Justin
On Mon, 16 Dec 2002, Jennifer Teig von Hoffman wrote:
> Howdy everybody,
> I know from the PIG release notes that I need to do this:
> * The file 'c:\ag\agapps\video-config' must be modified to reflect the
> correct host name for the PIG machine, as well as to reflect the correct
> device name for the video capture devices desired
> How do I find the correct device name for my video capture device? I'm
> using a USB camera which other applications see, but PIG doesn't.
> - Jennifer
