[AG-TECH] PIG question
Darin Oman
darin at ucar.edu
Mon Dec 16 10:34:59 CST 2002
To get the PIG to work with a USB or firewire camera, I was told to do
the following, which works for me:
1. Start PIG and log into VV.
2. Close vic window.
3. Open a command prompt, CD to c:\ag\agapps\bin
4. Type: mash vic <video IP address>/<port>/<ttl>
for example, if you want the test room, you'd type: mash vic
233.2.171.38/42002/127
5. In the vic window that appears, click on "settings."
6. Under "Encoder," click on "Device."
7. You'll probably be able to select your device, but I've had the best
luck with choosing "Microsoft WDM Image Capture (W32)" for any camera
I've tried.
8. You'll probably want to mess with the transmission settings a bit,
then click "transmit." Your video window should pop up.
If there's an easier way, I'd love to know it.
Darin
Jennifer Teig von Hoffman wrote:
> Howdy everybody,
> I know from the PIG release notes that I need to do this:
> * The file 'c:\ag\agapps\video-config' must be modified to reflect the
> correct host name for the PIG machine, as well as to reflect the
> correct device name for the video capture devices desired
> How do I find the correct device name for my video capture device? I'm
> using a USB camera which other applications see, but PIG doesn't.
> - Jennifer
