[AG-TECH] IGMPv3, Source Specific Multicast, fully supported in Windows XP
    Andrew Swan
    aswan at cs.berkeley.edu
    Fri Aug 16 19:16:51 CDT 2002
Tony Rimovsky writes:
> http://bmrc.berkeley.edu/mhonarc/openmash-users/msg00345.html
> syntax is vic s,g/port and, as of June 2002, vic could only receive
> from one s,g pair.
just to clarify, we changed the syntax to be s at g instead of s,g.
if you grab a current binary or source release, you also need to
apply a patch from the mailing list although if you grab source
from our cvs repository that ought to work...
> Jay, that note also says "there is no version of winsock that supports
> ssm -- until then it can't be done on windows".  given the information
> you have collected, this can probably work under xp.
we have neither ssm infrastructure nor an xp machine with
a suitable development environment available here but if
anybody is able to build mash with ssm support under xp i
would be interested in hearing about your experience and
would gladly commit any patches needed to make it work...
-Andrew
