[AG-TECH] physical security
Tony Rimovsky
tony at ncsa.uiuc.edu
Fri Aug 2 10:32:09 CDT 2002
I completely agree that this is problematic. However, with properly
planned dedicated space, a public AG is possible and setting up a few
of them in public spaces could be an interesting demo. Imagine random
walk by conversations between folks at nodes set up in common areas.
Or between a pair of museums as part of a technology demo.
Setup considerations:
Use security style cameras. Mark a spot on the floor for people to
stand. Make sure windows show local video. (To be really cool, tie
them to a tracking wand like they use in hospitals for directional
lighting. The only place I have seen this is in Labor and Delivery.
Wand would need to be secured somehow.)
Rear projection system with glass/plastic over the projection
surface for protection. This protects the projectors and computers.
Ceiling mounted mics, or directional mics pointed at the camera
focal point. There are probably more clever ways to approach this.
Lots of science museums and even some playgrounds use acoustical
tricks to carry sound from point-to-point without mics, and
eliminate background noise. You could make one point the camera
focal point and the other behind the screen, placing the mic's out
of reach.
Touch screen for venue navigation. or to keep it simple, just tie
the system to one venue.
On Fri, Aug 02, 2002 at 09:48:17AM -0500, Barbara A. Kucera wrote:
> You're absolutely right, Andrea! Let's hope that Robert's space
> administrators realize the folly of even considering doing such a thing.
> Barbara
> At 11:24 AM 8/2/2002 +0100, andrea jackson wrote:
> >Subject: RE: [AG-TECH] physical security
> >> Some thoughts to add to those from others ...
> >> Consider whether you can get the projectors inside a housing that
> >> is locked (a sort of projection tunnel fitted to the ceiling).
> >etc.
> >No, don't do it. It is wrong, it is a bad idea, and Robert knows it is.
> >Don't encourage it. It should be discouraged at all costs. I work in an
> >environment close to our own public cluster, and I've seen what they can do
> >to a black and white printer in the middle of the night, nevermind the AG
> >equipment. Robert is trying to run a professional facility. Putting him in
> >the position of never knowing if his AG node will still be intact in the
> >morning is bad practice.
> >Robert, how will you operate, test, and run maintenance on the node if it
> >is
> >in a public area?
> >Andrea Jackson
> >Manchester Computing
> >Tel +44 161 275 6090
> >accessgrid at man.ac.uk
> ________________
> Barbara A. Kucera
> Alliance/EPSCoR Liaison
> National Center for Supercomputing Applications (NCSA)
> University of Illinois at Urbana-Champaign
> (217) 244-0131 * Fax (217) 244-2909
> Computer Science is no more about computers than astronomy is about
> telescopes. - Edsger W. Dijkstra, computer science professor
