[AG-TECH] physical security
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Fri Aug 2 03:56:10 CDT 2002
Some thoughts to add to those from others ...
Consider whether you can get the projectors inside a housing that
is locked (a sort of projection tunnel fitted to the ceiling).
We looked at this for our new room (because of heat and noise,
not security) and had to rule it out on cost basis. Now we
can't hear the sound of the air conditioning for the sound of
the projectors!
Do as churches do (in the UK at least) - remove all mics and store
in a locked drawer or cupboard.
Have the rack (or whatever holds the computers, echo canceller
and audio interface stuff) in a locked cupboard (again like a
church) and/or use security bolts into the cage nuts.
If the building is patrolled, consider whether the 'tilt' alarms
would increase security on light things like cameras.
HTH
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
Sent: 01 August 2002 20:51
To: Robert Heckendorn; ag-tech at accessgrid.org
Subject: Re: [AG-TECH] physical security
off the top of my head,
there are a couple things you can do:
bolt and cable stuff down
or
remove and replace peripherals as needed
At 08:31 AM 8/1/2002 -0700, Robert B Heckendorn wrote:
>We are being asked to move our AG from a secure room to a public room
>with 24 hour student access. This seems like a very bad idea. Is
>anyone successfully running their AG in a room that can't be locked?
>If so then what precautions do you take so that camera etc don't
>get stolen.
>thanks for any help,
>| Robert Heckendorn | We may not be the only
>| heckendo at cs.uidaho.edu | species on the planet but
>| http://www.cs.uidaho.edu/~heckendo | we sure do act like it.
>| CS Dept, University of Idaho |
>| Moscow, Idaho, USA 83844-1010 |
Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
