[AG-TECH] RE: Fixing the audio connections etc in PS2 room
    Lance Long
    llong at evl.uic.edu
    Sat Sep 22 10:17:12 CDT 2001
The second mic is the one to the pc right? It should be muted for playback
on the pc, that way it still records, but you can't hear yourself. We also
should switch to the new speakers, but need to get something to connect it
to the system. I know andy rearranged some stuff before class the other
day and thats probably why things aren't matched. We should recable all
that though and make it look pretty, and get rid of the old speakers and
use the new....
...lance...
On Fri, 21 Sep 2001, Kyoung Shin Park wrote:
> Today, Seung and I tried to lable the audio connection.
> But we figured out that the audio connection is not matched with the plasma
> panel input source. So, before we start re-arranging the cabling in PS2
> room, I'd like to ask you
> what's needed, e.g. AG needs audio input/output.
> Next week we will start re-arrange cables.
> Let us know if anyone has any particular needs here.
> Thanks.
> -----Original Message-----
> From: Atul Nayak [mailto:atul at evl.uic.edu]
> Sent: Friday, September 21, 2001 11:02 AM
> To: Jason Leigh
> Cc: cavern at evl.uic.edu
> Subject: Re: Fixing the audio connections etc in PS2 room
> Okay...I think it's the second mic (not Polycom) that causes the feedback
> problem, and you end up hearing yourself through the speakers. I'll try to
> sort + label stuff.
> Atul
> On Fri, 21 Sep 2001, Jason Leigh wrote:
> > Hi Atul, Kyoung,
> > can you two fix/clearup/clarify the audio connections on the PlasmaPC.
> Right
> > now people are plugging in and unplugging audio rather than using the
> switch
> > and so there is a weird feedback problem somewhere that we need to fix.
> Also
> > we need to label the audio select box so it is obvious which button does
> > what.
> > Thanks
> > Jason
> > Jason Leigh, PhD
> > spiff at evl.uic.edu              Electronic Visualization Lab (M/C 154)
> > EVL Phone (312) 996-3002         University of Illinois at Chicago
> > EVL FAX   (312) 413-7585         851 S. Morgan St. Room 1120 SEO
> > http://www.evl.uic.edu/spiff     Chicago, IL 60607-7053
> ____________________________________________________________________________
> __
> Atul Nayak					  Dept. of Computer Science
> Electronic Visualization Laboratory               EVL FAX   : 312-413 7585
> University of Illinois at Chicago		  Home Phone: 312-775 7538
