[AG-TECH] Gentner AP-Ware?
    John Shalf
    jshalf at lbl.gov
    Thu Sep  6 12:48:48 CDT 2001
Works fine after the firmware upgrade (the upgrade is
absolutely necessary). The actual upgrade process is
non-eventful.
APWare does offer the convenience of adjusting sound levels
at the microphone source rather than on the audio capture PC
(a much more appropriate place for that adjustment).  Seems
to behave nicely on the same Win2k box that acts as the
display machine if you find it more convenient to run there.
Default baud rate (9600 baud) is too low, so after you get
it working, you should try increasing the baud rate (have to
do this from the Gentner front-panel as well as on the
APware side).  But don't do this until *after* the firmware
upgrade.
-john
Randy Groves wrote:
> Anybody have any experiences (good or bad) with this?  It seems to require
> a firmware upgrade, which gives me a little pause.  Are the preset files
> compatible?
> -randy
