[AG-TECH] VIC and RAT to easedrop
Marty Hoag
Marty.Hoag at NDSU.NODAK.EDU
Tue Oct 30 22:20:58 CST 2001
I've used both on various windows systems. You can even use Bob's
ddvic or non-ddvic if all you want to do is watch. Does rat show the
other sites in the member list? Did you check the various mixer levels
to make sure one isn't muted or has it's volume very low (double click
on the speaker icon). You might also check the rat options. I do have
one recent Dell Latitude C800 laptop that is a nice machine but when I
try to run rat I get weird noise after 30-60 seconds - I'm at home and
have forgotten the sound chip set that uses but haven't figured out
a solution. But we've used various versions of rat on other systems
(NT, W2K, even w98).
If you are on the moo you might be able to find someone who could
head to the test room to check things out with you.
Marty
