[AG-TECH] about echo cancellation equipment
    Robert Olson
    olson at mcs.anl.gov
    Thu May  3 09:23:09 CDT 2001
I'm of two minds on this. It would be cool if the echocancellation in the
chips worked well -- it would make simple installations work nicely (casual
audio use in an office PC, for instance). However, for an AG node with
multiple microphones it would pose a problem, since the cancellation would
likely suffer in a multiple microphone system. This is the difference
between the chip-based systems and the Gentner: the Gentner does echo
cancellation per-microphone.
Another interesting variation would be the use of multiple audio cards, one
per mic -- at $100 a pop for the cards, it would be less expensive. It's a
question of complexity vs price. The Gentner also does good things with its
support of the balanced audio connections, connectivity to other devices,
phone, etc.
Do you know if the echo cancellation options/control show up in the APIs
for programming the sound cards?
--bob
At 04:48 PM 5/3/2001 +0800, lujian wrote:
>         I heard that soundcard powered by Crystal/Cirrus SoundFusion  DSP
> (digital signal processor) can do echo cancellation work . Is it possible
> that we use such a soundcard as a second choice of Gentner system?
>         And is there anyone who can tell the difference between the
> card-based echo cancellation and Gentner echo cancellation?
>some reference sites:
>http://www.voyetra-turtle-beach.com/site/press/releases/santacruz090100.asp
>http://www.cirrus.com/design/products/overview/index.cfm?ProductID=42
