[AG-TECH] AG hardware help
    Jonas Talandis
    jonast at evl.uic.edu
    Thu Mar 29 14:22:15 CST 2001
Seems that your video machine has only one PCI slot. You need one slot for
each video capture card, usually three or four in most nodes.....AG history
has been that most hardware problems are related to plug-in compatibility.
At 02:12 PM 3/29/2001, Russ Wolf wrote:
>Satish,
>I noticed that the Display machine was opnly a 100MHz bus and the others
>are 133MHz bus machines.  Is there a reason you chose that ?  The
>Display Machine the the machine that does the most 'work' during an
>access grid event and should be the best machine you get.  The video
>capture machine does not get CPU or memory bogged like the display does.
>         -Russ Wolf, Boston University
>Satish Devarapalli wrote:
> > Hi all,
> > I am Satish Devarapalli from Illinois Institute of Technology. we are in
> > the process of building a node. below is the configuration information for
> > the display,video,audio and control machines. please tell me your
> suggestions
> > on this configuration.
> > Details:
> > __________
> > Display Machine
> > Processor 2 Pentium III 850Mhz/100 w/256K Cache
> > Intel
> > MotherBoard 1 Dual RDY, Cache on CPU, BX Chipset
> > Super DBE
> > BoardSpecs 1 (5)PCi,(2)ISA (1 is shared), AGP Video
> > BoardSpecs 1 AMI BIOS, Ultra DMA IDE ON BOARD
> > BoardSpecs 1 4 DIMMS, Wake-on-Lan, USB
> > Memory 1 256 MB SDRAM, DIMM, 133Mhz ECC
> > Disk 2 18GB, 10,000 RPM, LVD 160MB/Sec 4MB Cache
> > Seagate
> > SLEDS 2 Removable Cannister, w/ Fan & Key Lock LED for IDE
> > Floppy 1 3.5" Floppy and System Cabling MPF-920-1-131
> > PC Card Reader 1 PCMCIA PC Card Reader
> > 0260.307.001
> > CD ROM 1 52X Sony IDE CD-ROM
> > Tape Drive 1 Iomega Zip Drive 100MB, IDE
> > Wide Ctrlr 1 PCi LVD Ultra 160 SCSI Controller 160Mb/Sec
> > Adptc29160U
> > Video Brd 1 32MB Millenium G450 Dual
> > MATROX
> > Ethernet 1 Intel PCI Pro/100+ Server Adapter
> > PILA8470
> > Sound 1 PCI-512 Soundblaster CT 4790
> > Creative Labs
> > CPU ATX Rack 1 4U BLACK Rackmount (8)5.25" Bays, 300 Watt
> > Rack Rails 1 Sliding Rails (one per rack shelf) RACK-6CA300
> > Keyboard 1 104 SAG Keyboard & 3 Button Logitech Mouse
> > Warranty 1 3 Year Warranty
> > SERVICE 1 1 Year NBD on-site, Banctec Workstation
> > System Total 1 $3,021 Shipping not included.
> > __________________________________________________________________
> > Video Machine
> > Server 1
> > Processor 2 Pentium III 866Mhz/133 w/256K Cache
> > Intel
> > MotherBoard 1 Dual RDY PIII, FCPGA
> > Super 370DER
> > BoardSpecs 1 (1) 64bit 66MHz PCI Slot
> > BoardSpecs 1 up to 4GB SDRAM, 4 DIMMS
> > BoardSpecs 1 Integrated Ethernet, Int. 160 SCSI
> > Memory 1 256 MB SDRAM, DIMM, 133Mhz ECC, Registered
> > Seagate
> > CPU ATX Rack 1 2U BLACK Rackmount (4)3.5" Removable - 300 Watt
> > CPU ATX Rack 4 1U White Rackmount (2)3.5" removable SCA bays,
> > 245watt
> > Rack Rails 5 Sliding Rails (one per rack shelf)
> > RACK-6CA300
> > SERVICE 1 1 Year NBD on-site Server
> > System Total 1 $3,238 Shipping not included
> > Control Machine
> > Processor 1 Pentium III 700Mhz/100 w/256K Cache
> > Intel
> > Super DBE
> > Disk, EIDE 1 10GB, IDE 5400 RPM, Ultra 66
> > SLEDS 1 Removable Cannister, w/ Fan & Key Lock LED for IDE
> > MATROX
> > Ethernet 1 Intel PCI Pro/100, Management Adapter
> > PILA8461
> > Creative Labs
> > Workstation
> > System Total 1 $1,752 Shipping not included
> > Audio Machine
> > Intel
> > Super DBE
> > Memory 1 128 MB SDRAM, DIMM, 133Mhz ECC
> > Video Brd 1 ATI 8MB AGP Video
> > ATI
> > Ethernet 1 3COM PCI 10/100 10BaseT, RJ45
> > 3C905-TX
> > Creative Labs
> > System Total 1 $1,545 Shipping not included
> > Thank you in advance
> > Satish
> ____________________________________________________________________________
> > Satish Devarapalli
> > 3140 S.Michigan Avenue, #801
> > Chicago, IL-60616
> > ph:(312)-791-1180
