[Fwd: [Fwd: [AG-TECH] Matrox G450 linux problems]]
    Russ Wolf
    russ at bu.edu
    Mon Mar 26 12:30:26 CST 2001
Russ Wolf wrote:
> Russ Wolf wrote:
> > from my experience the G450's don't like XFree86 version 3.x.x.x they
> > really need a recompiled XFree86 version 4.x - but XFree-4 is not
> > standard RedHat until 7.0 so you're better off with having built your
> > own.
> > Once you have it working you can only have the 1st of the two monitors
> > display with a refresh rate over 60Hz and the second one is stuck at
> > 60Hz
> >         -Russ
> > "John A. Greenfield" wrote:
> > > Has anyone else had problems with the linux install on some Matrox G450
> > > Dual haed cards ? Some cards seem to work fine, others seem to hang the
> > > graphics install mode and always hang X after a text mode install.
> > > Does anyone have fixes for this ?
