[AG-TECH] Matrox G450 linux problems
Bob Olson
olson at mcs.anl.gov
Mon Mar 26 12:24:45 CST 2001
I think the fix is a new version of XFree86. Unfortunately, that probably
doesn't help you much. The path of least resistance currently is to not
use G450s on the Linux side. I will be releasing a RedHat 7.1 version of
the capture machine when 7.1 comes out of beta.
If you are interested in trying things out, you can install the 7.1 beta,
and then install the AG RPMs on top. That combination worked fine for me
in testing (although I have not tried it with a G450 yet).
--bob
On Mon, 26 Mar 2001, John A. Greenfield wrote:
> Has anyone else had problems with the linux install on some Matrox G450
> Dual haed cards ? Some cards seem to work fine, others seem to hang the
> graphics install mode and always hang X after a text mode install.
> Does anyone have fixes for this ?
> Thanks
> John Greenfield
> green at ahpcc.unm.edu
> University of New Mexico
> THE ALBUQUERQUE HIGH PERFORMANCE COMPUTING CENTER
> Office # 505-277-8249
> Direct # 505-277-9545
> Fax # 505-277-8235
