[AG-TECH] Help on Beaconviewer
Allan Kenneth Spale
aspale1 at uic.edu
Fri Mar 9 15:15:34 CST 2001
Ravikiran,
There is a web version of the beaconviewer that EVL/UIC finds adequate.
The URL is: http://beaconserver.accessgrid.org:9999/ . That will at least
give you the information you need to start. I have not used the Java
program for the BeaconViewer.
If you have not done so already, check out this URL:
http://www-fp.mcs.anl.gov/fl/accessgrid/ . Click on the Technical
Resources link and you will find useful AG information and software
downloads (also info on BeaconViewer).
Allan Spale
EVL / UIC node-op
On Fri, 9 Mar 2001, Ravikiran Madduri wrote:
> Hi
> My name is Ravi K Madduri.Iam working with Dr.Hood in IIT.We are planning
> to have a AG node in IIT.But I have some problems running the beacon
> Viewer program.Whenever i run the viewer in the following way:
> java BeaconViewer -group 233.2.171.1 -port 56464 -server
> beaconserver.accessgrid.org -serverport 9998 -interval 30 -verbose I get
> the following error in GUI Server reply error and in the command window I
> get ClientRecvSessionName error:
> I would greatly appreciate if some one helps me out
> Ravikiran
