[AG-TECH] Another Distributed Slide Show Format
Allan Kenneth Spale
aspale1 at uic.edu
Fri Mar 2 10:23:33 CST 2001
This was suggested by Don Morton concerning maybe providing another option
for a distributed slide show.
Allan
EVL / UIC node-op
---------- Forwarded message ----------
Date: Fri, 2 Mar 2001 11:10:38 -0500
To: Allan Spale <aspale at evl.uic.edu>
Cc: Don Morton <morton at cs.umt.edu>, agdp at accessgrid.org
Subject: Re: [agdp] AGDP Wish List
This is a cool idea, and I wonder what list it would be appropriate to
migrate the discussion to. ag-tech perhaps? I'm not sure if there's any
current mechanism for AG software wish list, but if there is I'm sure
somebody on this list can point us to it (although given that resources
are already being made available maybe it's not a wish list item?).
- Jennifer
On Fri, 2 Mar 2001, Allan Spale wrote:
> On Thu, 1 Mar 2001, Don Morton wrote:
> > Allan Spale wrote:
> > > PowerPoint-- http://cthulhu.ale.org/ale-archive/ale-2000-10/msg00025.html
> > > contains a response that StarOffice *seems* to be able to deal with
> > > PowerPoint. Don't know what to do from there, though. Would dppt stuff
> > > still work with StarOffice?
> > I would be interested in (maybe this is a little off this list) in
> > a distributed PDF reader, whereby folks can use any software they
> > want to produce their shows, then convert to a standard PDF where
> > controls can be passed across the nodes. I'm getting ready to seek
> > some funding that would assign a student or two to something like this.
> > That way, you use Powerpoint, Staroffice, Corel, or whatever you want,
> > to produce your show.....
> That's a really good point...and it seems possible. I had a class last
> semester where the professor gave his "slides" for each class using Adobe
> Acrobat. If you did not know what the professor was running, you could
> have mistaken it for PowerPoint.
> > Don Morton http://www.cs.umt.edu/u/morton/
> > Department of Computer Science The University of Montana
> > Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
> Allan
> EVL / UIC node-op
