[AG-TECH] Wall material for AGnode
Don Middleton
don at ncar.ucar.edu
Tue Jun 12 15:52:04 CDT 2001
For our new lab/AG facility we're using WhisperWall which is a fiberboard
material attached over drywall and covered with your choice of fabric. It
does seem to deaden the room quite a bit.
don
----- Original Message -----
To: "Supreeya Miller" <Supreeya.Miller at usm.edu>
Cc: <ag-tech at mcs.anl.gov>
Sent: Tuesday, June 12, 2001 11:09 AM
Subject: Re: [AG-TECH] Wall material for AGnode
> Supreeya Miller wrote:
> > Hello everybody,
> > CHL is in the process of setting up a room from an existing office space
for
> > the AGnode. There are walls have to be removed and added. They want to
> > know whether there has to be a special material applied on the walls or
> > special type walls, may be for creating good sound. I'm not able to
answer
> Hmmm. First - I'm not an acoustic engineer but the room we are using
> was originally developed for interactive TV. They put some 2'x2' panels
> which are a couple inches thick (I think they are made of some solid
> foam material) and covered with somewhat light blue cloth flat on the
> back wall. On the side walls they put the same panels but zig zagged
> them out a few inches every other seam so the wall surface isn't flat.
> But I don't know if they did that for acoustic or esthetic effect.
> ;-) You can see part of the back wall at
http://www.ndsu.nodak.edu/instruct/juell/remote/remote00/access-grid0008/mvc
> but I don't think I have a good picture of the sides (I could make some
> if someone REALLY wants them).
> I think a hard rear wall could make the room very "live" and using
> some sort of acoustic material might help kill the audio reflections so
> you get a dryer sound. At least personally, a room that is too live can
> get old fast. But I'm sure your architect may know more about that.
> One ongoing discussion though is what color to use on walls. I know
> ANL has used black curtains and I think I've heard them say they
> wouldn't use that color if they had it to do over again. The light blue
> on our back wall seems to work ok (but we have lighting challenges and
> camera angles that don't always take advantage of that). Others can
> probably explain what the ideal background colors would be.
> Marty
> > this question. Since they ask and willing to do the best thing for
AGnode,
> > I think it is worth try to answer this question. Can anyone help me,
> > please? (I attached a picture of the space where we will setup an
AGnode.
> > Supreeya Miller
> > AGroom.jpg Type: JPEG Image (image/jpeg)
> > Encoding: base64
