[AG-TECH] Some mic questions
Jonas Talandis
jonast at evl.uic.edu
Mon Jul 16 10:17:37 CDT 2001
I'm curious about the design limits of the Gentner phantom power supply.
George mentioned he had 8 mics running, which seems pretty good. I've never
experienced the pick up problem you describe, perhaps it's a connector issue?
Also I agree with the previous comment from the group about choir mics.
Picking up a "choir" is a lot different than a lone comment from an
audience. Even if you beat the problems from HVAC and other audible
interference it's a good idea to keep a boom or hand-held mic available for
audience participation.
JT
At 06:56 AM 7/16/2001, Robert Olson wrote:
>At 05:53 PM 7/13/2001 -0500, Jonas Talandis wrote:
>>Sounds like rubbish to me. Most nodes I know have the mics directly
>>connected to the Gentner, which is important to echo performance. Has
>>anyone experienced any phantom power problems?
>The only issue I've ever seen regarding to phantom power is the rare
>occasion where a mic isn't picking up for some reason, and toggling
>phantom power on and off brings it back.
> From the PCC-160 spec sheet, phantom power requirement is 12-48 V, 4 mA.
> From the Gentner specs, it's providing 24V phantom power.
>No problem.
>The CM31 looks to be quite similar to hte Audio-Technica hanging condenser
>mics we are using in our seminar room for the audience. They seem to work
>quite well; you do need to experiment with placement to ensure full coverage.
>--bob
>>On Fri, 13 Jul 2001, Jonathan C. Humfrey wrote:
>> > I just spoke to someone at Crown Audio who told me the Gentner does not
>> > have enough power to run the Crown PCC mics and that I needed to by a
>> > seperate phantom power supply from Crown. Does anyone know about this? I
>> > am waiting on our Gentner now.
>> > Also, does anyone have experience using the Crown CM31 (which is a choir
>> > mic) or equivalent for miking a large area/audience?
>> > Thanks,
>> > Jonathan Humfrey
