[AG-TECH] Adjustments to AGN Specs
Bob Riddle
bdr at internet2.edu
Wed Jan 10 08:35:23 CST 2001
Don,
I'm using the onboard Intel NIC in several of my nodes. It seems to work
just fine.
On Wednesday 10 January 2001 09:55, Don Morton wrote:
> 1) Due to unexpected configuration of Display machine motherboard,
> I'm running 3 projectors plus monitor off of the G200 Quad
> card. As it turns out, the G200 won't cooperate with any
> other video adaptor in the machine unless its a Matrox
> (and the restriction is probably more specific than just that).
> So, at this point everything runs off of the G200 Quad. Naturally,
> it's working in the sense that I can display on all three
> projectors plus monitor. However, I have concerns that it won't
> handle the load of a real AGN session. Does anybody have
> experience with this? I don't know if I want to leave things
> the way they are, or if it would be prudent to get a new
> motherboard with AGP slot, or some other solution. Money
> doesn't flow freely here, but an AGN that can't process all
> these graphics isn't desirable, of course :)
> 2) On the video capture machine, there are only two free PCI slots
> for the WinTV cards. One slot is taken up by the NIC, yet
> there is also an onboard 10/100 port. I understand that the
> Intel PCI Pro/100+ NIC that's in there does some processing
> of a level or two of the TCP/IP stack, so I'm wondering if
> pulling that out and using the onboard 10/100 would critically
> cut the network capabilities of that machine. Again, does anybody
> have experience enough to provide advice?
> We're still several weeks away from even getting our high-speed network
> connected in to the AGN, so I can't test this myself. Which reminds
> me, U. Montana has an opening for a Networking position (I don't know
> exactly at what level) - if anybody's interested, I can find more
> info for you. In general, low monetary rewards, high peace-of-mind
> rewards :)
> Don
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Phone: 734.913.4257 Fax: 734.913.4255
