[AG-TECH] Adjustments to AGN Specs
Don Morton
morton at cs.umt.edu
Wed Jan 10 09:23:12 CST 2001
Robert Olson wrote:
> At 06:55 AM 1/10/2001 -0800, Don Morton wrote:
> > 1) Due to unexpected configuration of Display machine motherboard,
> > I'm running 3 projectors plus monitor off of the G200 Quad
> > card. As it turns out, the G200 won't cooperate with any
> > other video adaptor in the machine unless its a Matrox
> > (and the restriction is probably more specific than just that).
> Is this the case under win2k still? The OS should allow this; does the machine
> boot up? I've run a mix of matrox and other cards without problem in the past.
> Is this the machine with the ATI AGP adapter onboard?
I'd better investigate further. Initially, I screwed up and had the
mouse/keyboard
cables reversed, with both the G200 and an ATI PCI card in. I read in
the G200 manual that the G200 only works with other Matrox cards, so
figured that was the problem. Then I discovered my reversed cables :)
It turns out there is no ATI AGP adapter onboard, though that was specified in
the quote - this is something I'll take up with SAG.
> > We're still several weeks away from even getting our high-speed network
> > connected in to the AGN, so I can't test this myself. Which reminds
> > me, U. Montana has an opening for a Networking position (I don't know
> > exactly at what level) - if anybody's interested, I can find more
> > info for you. In general, low monetary rewards, high peace-of-mind
> > rewards :)
> :-). Betcha it doesn't cost as much to live out there as it does here...
In places like Missoula, it tends to be higher than folks expect, though
I don't think it's as bad as the coasts.
Don Morton http://www.cs.umt.edu/u/morton/
Department of Computer Science The University of Montana
Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
