[AG-TECH] Wups, problem with latest VV release
Tom Coffin
tcoffin at ncsa.uiuc.edu
Wed Jan 3 16:42:56 CST 2001
here's a strange error I'm getting after reinstalling
vv on the display machine. I'm getting the following on
the linux machines: (everything works, audio and video, but
the error scrolls on...)
[access at ag-access-audio access]$ arm-eventlistener Didn't find name
service: org.omg.CORBA.ORBPackage.InvalidName Got event channel
org.omg.CosEventChannelAdmin.StubForEventChannel at 80dad0a Got ANY type 16
channel listener caught org.omg.CORBA.BAD_OPERATION:
org.omg.CORBA.BAD_OPERATION: at
ag.MediaEventHelper.extract(MediaEventHelper.java:37) at
ag.SdpChannelListener.push(SdpChannelListener.java:88) at
org.omg.CosEventComm._PushConsumerImplBase._OB_op_push(_PushConsumerImplBase.java:41)
at
org.omg.CosEventComm._PushConsumerImplBase.invoke(_PushConsumerImplBase.java:109)
at com.ooc.CORBA.BOA._OB_dispatch(BOA.java:1301) at
com.ooc.CORBA.GIOPServerWorker.dispatchRequest(GIOPServerWorker.java:417)
at
com.ooc.CORBA.GIOPServerWorkerThreaded.dispatchRequest(GIOPServerWorkerThreaded.java:317)
at com.ooc.CORBA.GIOPServerWorker.execute(GIOPServerWorker.java:258) at
com.ooc.CORBA.GIOPServerWorkerThreaded.receiverRun(GIOPServerWorkerThreaded.java:567)
at
com.ooc.CORBA.GIOPServerWorkerThreaded$ReceiverThread.run(GIOPServerWorkerThreaded.java:52)
Got ANY type 16
etc...
any ideas on this?
______________________________________
On Wed, 3 Jan 2001, Robert Olson wrote:
> In doing some cleanup of packages being installed in the VV software, I've
> removed the JDK that was there and replaced with the redistributable JRE.
> Unfortunately I didn't update the VV scripts that invoke java. If you get
> errors with the latest software (probably after doing a clean install, not
> an update from an earlier version), change the file
> /usr/local/ag/lib/machine-config to have the line
> JAVA=/usr/local/ag/jre1.2.2/bin/java
> instead of its previous value.
> --bob
