[AG-TECH] Wups, problem with latest VV release
    Robert Olson
    olson at mcs.anl.gov
    Wed Jan  3 14:31:12 CST 2001
In doing some cleanup of packages being installed in the VV software, I've
removed the JDK that was there and replaced with the redistributable JRE.
Unfortunately I didn't update the VV scripts that invoke java. If you get
errors with the latest software (probably after doing a clean install, not
an update from an earlier version), change the file
/usr/local/ag/lib/machine-config to have the line
	JAVA=/usr/local/ag/jre1.2.2/bin/java
instead of its previous value.
--bob
