[AG-TECH] RAT not finding audio card
Don Morton
morton at cs.umt.edu
Wed Feb 28 10:51:55 CST 2001
All, to add more info to the equation (please just ignore this all
if it ain't your cup of tea :):
- I am using the Creative SB 128 audio cards (I think, just
for the halibut, I'll pull two of them just to remove them
from the equation.)
- I am using the OSS drivers obtained from 4front
- I am appending the output of "cat /dev/sndstat" to this message.
I don't know what "all" of it means (yet), but it appears that things
are being found, anyway....
Thanks again, Don
Don Morton wrote:
> Hi all, I've found the likely reason that I can't receive anybody's
> audio is that rat isn't finding my audio card. Apparently, being
> able to hear a Neil Young cd or a RealAudio stream (which I guess
> operates in half-duplex) is no guarantee that rat will work (which
> I guess operates in duplex. Essentially, when I go through the audio
> menu of rat, under the "select alternate devices" (or something like
> that section, the only option is something like "No Audio Device"
> I "guess" that maybe there's an IRQ assignment problem that "maybe"
> I need to look into but, in /var/log/messages, at boot, I get
> a message saying:
> Feb 27 15:34:57 AGNAudioCapture modprobe: modprobe: Can't locate module sound-sl
> ot-0
> Feb 27 15:34:57 AGNAudioCapture modprobe: modprobe: Can't locate module sound-se
> rvice-0-6
> Does anybody know if these are actually needed by rat, or am I probably safe
> ignoring
> this?
[root at AGNAudioCapture log]# cat /dev/sndstat
OSS/Linux 3.9.4c (C) 4Front Technologies 1996-2000
License serial number: N02680983
Options: APCI
This copy of OSS is licensed to Don Morton
Build: 2.2.18-SMP
Card config:
Ensoniq AudioPCI 97 at 0xdf00 irq 20
Ensoniq AudioPCI 97 at 0xde80 irq 18
Ensoniq AudioPCI 97 at 0xdd80 irq 16
Audio devices:
0: Ensoniq AudioPCI97 (DUPLEX)
1: Ensoniq AudioPCI97 (playback only)
2: Ensoniq AudioPCI97 (DUPLEX)
3: Ensoniq AudioPCI97 (playback only)
4: Ensoniq AudioPCI97 (DUPLEX)
5: Ensoniq AudioPCI97 (playback only)
Synth devices:
Midi devices:
0: AudioPCI97
1: AudioPCI97
2: AudioPCI97
Timers:
0: System clock
Mixers:
0: AudioPCI 97 (STAC9708)
1: AudioPCI 97 (STAC9708)
2: AudioPCI 97 (STAC9708)
