[AG-TECH] mjpeg test
Bob Riddle
bdr at internet2.edu
Tue Dec 11 09:36:00 CST 2001
hmmm ... the only problem I've experienced is that when I run the wrong vic,
you never see the mjpeg stream.
Quoting "Gurcharan S. Khanna" <Gurcharan.S.Khanna at Dartmouth.EDU>:
> hi bob,
> i'm connected as per your instructions but don't see you. i see everyone
> else.
> is there some setting i need to adjust???
> thanks,
> -gurcharan
> Gurcharan S. Khanna
> Associate Director
> Research Computing
> 6224 Baker/Berry
> Dartmouth College
> Hanover, NH 03755
> gkhanna at dartmouth.edu
> office: 603-646-1644
> fax: 603-646-1042
> http://research.dartmouth.edu
> http://www.dartmouth.edu/~rc
> http://www.dartmouth.edu/~gkhanna
> --- Bob Riddle wrote:
> I've set up a mjpeg test in the AG Test Room. Its a pretty ratty
> stream, only
> 5 mbps using CIF format but it's a test of the stuff I've gloomed
> together. In
> order to run a hogher rate in NTSC format I need to build the openmash
> vic from
> CVS - something I haven;t had a chance to do as yet.
> Anyway, to see if you can see anything:
> Download the openmash vic for windows on your display machine
> (www.openmash.org)
> get your AG display node into the AG test room.
> Kill the AG vic window.
> open a cmd (DOS-like) window and star the openmash vic ".\vic
> 233.2.171.38/42002"
> Let me know what you see, think, etc.
> I hope to have the necessary vic ready for a 10mbps test next Tuesday
> morning.
> --- end of quote ---
