[AG-TECH] RH 7.1 and video instability
Robert Olson
olson at mcs.anl.gov
Tue Aug 14 20:13:04 CDT 2001
Oh, that reminds me. Ran across this article the other day:
http://www-106.ibm.com/developerworks/linux/library/l-hw2.html
From its intro:
>One of Linux's claims to fame is its legendary stability. But the most
>stable operating system in the world won't do you any good if your
>hardware is defective or misconfigured. In this article, Daniel Robbins
>shares his experiences in getting his NVIDIA TNT graphics card working
>under Linux using NVIDIA's accelerated drivers. As he does, he'll show you
>how to diagnose and fix IRQ and PCI latency timer issues -- techniques you
>can use to ensure that your systems don't experience lock-ups,
>inconsistent behavior, or data loss.
Another piece of information folks should send when debugging hangs or
crashes is the interrupt assignments, like so (from the FL Library video
capture machine):
$ cat /proc/interrupts
CPU0 CPU1
0: 53452187 53423538 IO-APIC-edge timer
1: 148 129 IO-APIC-edge keyboard
2: 0 0 XT-PIC cascade
8: 0 1 IO-APIC-edge rtc
9: 93086119 93066418 IO-APIC-level bttv, bttv
10: 1144679067 1144195741 IO-APIC-level eth0
11: 46647656 46655902 IO-APIC-level bttv
12: 614 581 IO-APIC-edge PS/2 Mouse
13: 1 0 XT-PIC fpu
14: 4759600 4740341 IO-APIC-edge ide0
15: 46651792 46617554 IO-APIC-level bttv
NMI: 0
ERR: 0
--bob
At 04:29 PM 8/14/2001 -0700, Wesley Lau (DSD student -DAA) wrote:
>I suspect my video capture box instability is due to an interrupt
>conflict. I am using three WinTV Hauppauge cards in an Asus P3V4X MB.
>Acording to /proc/pci, two TV cards and the USB controller are sharing
>IRQ 9, and one TV card and ethernet card are sharing IRQ 5.
>I'll try disabling the USB controller and removing one of the unused TV
>cards (on IRQ 9) and see what happens. My video machine has mysteriously
>begun working again, btw. Anyone know how I might force the TV cards to
>use different interrupts? The TV cards have no jumpers and are all PCI.
>thanks
>wes
>On Tue, 14 Aug 2001, Randy Groves wrote:
> > I'm running my video box (am I assuming correctly that you mean the video
> > capture box?) on 7.1 and have had no problems. I have been keeping the
> > installation up to the latest versions on Robert's Linux site (well at
> > least current as of 7 weeks ago, before my vacation). We're using the
> > Hauppage 401 cards.
> > -randy
> > At 01:06 PM 8/14/2001 -0500, Robert Olson wrote:
> > >That's been a niggling worry of mine with 7.1, especially since I've not
> > >run a 7.1 node in-house here. I hope to install 7.1 on our PortaAG node
> > >and see what happens. (I tried some short-term tests that turned out
> okay,
> > >but not really any heavy use).
> > >What hardware are you running with?
> > >--bob
> > >At 10:59 AM 8/14/2001 -0700, Wesley Lau (DSD student -DAA) wrote:
> > >>Hello,
> > >>I upgraded my ag node to RH 7.1, and while the audio machine works fine
> > >>(after a few driver issues), the video machine is quite
> unstable. After a
> > >>fresh install, it works for a while then completely freezes up, requiring
> > >>a hard reboot. After that, the video box freezes up everytime I
> enter the
> > >>Lobby, no matter how many reboots. Anyone know why and are there any
> > >>solutions? I think I'll have to downgrade to the 6.2 iso.
> > >>thanks
> > >>Wesley Lau
