vrm-eventlistener / VIC problem
Robert Olson
olson at mcs.anl.gov
Tue Sep 12 10:00:10 CDT 2000
>Are you using the RedHat kernel? I'm guessing that when you upgraded
>you started using the "bad" video capture drivers that come with it.
>Unless Bob O. has updated his customization script to install the "good"
>video capture drivers for the RedHat 2.2.16-3 kernel you'll need to
>install the "good" drivers manually.
I just built the drivers for the 2.2.16-3 kernel:
http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/bttv-0.6.4h-2.2.16-3.ta
r.gz
http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/bttv-0.6.4h-2.2.16-3smp
.tar.gz
If you built a custom kernel, you should download the bttv source and
rebuild the drivers yourself.
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20000912/4d56db26/attachment.htm>
