Win2k ddvic release: 2000-1127
Robert Olson
olson at mcs.anl.gov
Mon Nov 27 21:03:28 CST 2000
There's a new vic at:
http://www-unix.mcs.anl.gov/~olson/AG/Software/NT/ddvic-2000-1127.zip
It requires the latest AG software install (for the IJL libraries).
New features:
Improved jpeg rendering (uses HW overlays when possible). To enable the
MMX/overlay support, press 'h' in the window. Press 'H' to disable it.
Window gluing: if you type 'g' at a window, it won't be moved by the
autoplacer. This way you can lay out the windows you want at the sizes you
want, glue them, and the autoplacer will leave them alone when you re-apply
the placement to tightly tile the ones you're not as interested in. Press
'G' in the window to unglue it.
The autoplacer in this version also ignores muted streams when doing the
placement, so if you mute them in the thumbnails before autoplacing then
they won't show up at all.
--bob
