Fwd: IJL v1.5
Robert Olson
olson at mcs.anl.gov
Mon Nov 27 19:19:03 CST 2000
To get this in the archives. This affects folks using the latest vic for
windows 2k build for jpeg display.
--bob
>Date: THU, 16 NOV 2000
>From: The IntelX JPEG Library Team <pto at mailbox.intel.com>
>X-Subject: M_015344
>Subject: IJL v1.5
>To: Intel Customers <intel at mailbox.intel.com>
>You are receiving this email because you have registered and downloaded
>the Intel® JPEG Library. Additional contact information is at the end of
>this email.
>Dear Developer:
>We have discovered a couple of issues in IJL v1.5 and are notifying you of
>them. There is one bug and one performance issue. Below is a discussion
>of the performance issue and a workaround for the bug.
>CPU Detection and Selection
>The CPU-type auto-detection code in IJL v1.5 does not work properly. As a
>result, IJL defaults to blended code for all processors. This means
>slower performance on some machines.
>In order to workaround this problem, you must add a key to the Windows
>Registry that specifies witch processor's code to use.
>Create the key USECPU key in HKEY_LOCAL_MACHINE\Software\Intel
>Corporation\PLSuite\IJLib. The value is a DWORD and should be one of the
>following values:
>0 - Blended code (option for all non-Intel processors)
>3 - Code optimized for Pentium® processor with MMX Technology
>4 - Code optimized for Pentium II processor
>5 - Code optimized for Pentium III processor
>6 - Code optimized for Pentium 4 processor
>We are working on a patch to IJL that fixes this issue, but in the
>meantime this key must be used in order to use the highest performance code.
>Apparent Performance Decrease
>Additionally, starting with IJL v1.5, we are being more rigorous with our
>internal checks of data in order to provide better image quality. On a
>given processor, for the same image, IJL v1.5 will be 2 - 3% slower than
>when using the previous version, IJL v1.1.
>We apologize for these inconveniences,
>The Intel JPEG Library Team.
>If you dont wish to receive future mailings, please send a note to
>developer_support at intel.com stating that you wish to unsubscribe, include
>your email and cite which library list you wish to be removed from (in
>this case, IJL). Please do not reply to this message.
>*Third party marks and brands are the property of their respective owners
