Addition to spec
Bob Olson
olson at mcs.anl.gov
Fri May 26 13:55:39 CDT 2000
What's the RU-LA2D? was that one of the other boxes I had? If so, it does
roughly the same thing, but I liked the MM100 best of the ones I tried.
(Just looked, the library node here has the RU-LA2D and it does a fine
job too). Not as adjustable as the MM100 which is why I recommeded the
latter.
--bob
On Fri, 26 May 2000, Karen D. Camarda wrote:
> Is this device a recommended replacement for the RU-LA2D level balancer,
> or does it do something else?
> Karen Camarda
> KU Chemical Engineering
> On Fri, 26 May 2000, Robert Olson wrote:
> > Just wanted to send a note about a very useful device that helps in level
> > matching quite a bit. Consider it an official addition to the AG node spec :-).
> > It's an ATI MatchMaker MM100. It converts between pro-audio and
> > consumer-audio levels, which goes between the Gentner and the PC. It has
> > XLRs for going to the gentner, and RCAs for going to the PC. This lets you
> > use a standard 1/8" to RCA cable for the PC side, and the genetner/XLR
> > cables you all love for the gentner side.
> > http://www.markertek.com/MTStore/product.CFM?BaseItem=MM100
> > --bob
