Addition to spec
Karen D. Camarda
kcamarda at tal.engr.ukans.edu
Fri May 26 13:50:59 CDT 2000
Is this device a recommended replacement for the RU-LA2D level balancer,
or does it do something else?
Karen Camarda
KU Chemical Engineering
On Fri, 26 May 2000, Robert Olson wrote:
> Just wanted to send a note about a very useful device that helps in level
> matching quite a bit. Consider it an official addition to the AG node spec :-).
> It's an ATI MatchMaker MM100. It converts between pro-audio and
> consumer-audio levels, which goes between the Gentner and the PC. It has
> XLRs for going to the gentner, and RCAs for going to the PC. This lets you
> use a standard 1/8" to RCA cable for the PC side, and the genetner/XLR
> cables you all love for the gentner side.
> http://www.markertek.com/MTStore/product.CFM?BaseItem=MM100
> --bob
