ANNOUNCEMENT: New beacon version available
Robert Olson
olson at mcs.anl.gov
Wed May 10 12:48:20 CDT 2000
RPMs for the latest version of the multicast beacon are now availalbe.
Please install on your nodes (on the video capture machine is good) asap.
This replaces the old version. It has a number of enhancements and is more
reliable.
You should be able to install with the following commands as root:
/etc/rc.d/init.d/nlanr-beacon stop
rpm -U
http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS/nlanr-beacon-0.63-
1.i386.rpm
/etc/rc.d/init.d/nlanr-beacon start
To be safe, reboot your machine after that.
This RPM requires the jre 1.2.2 rpm to be installed:
rpm -i
http://www-unix.mcs.anl.gov/~olson/AG/Software/Linux/RPMS/jre-1.2.2-4.i386.rpm
As a reminder, to have the beacon start at boot run as root:
/sbin/chkconfig nlanr-beacon on
This RPM installs a viewer that you can invoke with
/usr/local/ag/bin/nlanr-viewer
You can also see the current multicast state by viewing the webpage:
http://beaconserver.accessgrid.org:9999/loss
--bob
