freaky vic bug???
Benjamin Snyder
bens at osc.edu
Thu Jun 15 07:47:37 CDT 2000
I discovered a 'problem' with vic on the porta-node (might be specific to that
install on that node). I was firing up the dppt client on the display machine
and mis-typed the command and dppt didnt start correctly. It started a window
over one of the windows on my extended desktops (projectors). When I killed it
to start another, the window that was covered up didnt redraw, as soon as I
started to drag it back to desktop 0 it redrew as it crossed desktops.
I dont know if this is a display driver problem in Win2k, or if it's a vic
problem. I also didnt know if anyone else had come across this (I've not seen
it in the mailings), but thought I'd share just in case.
Ben Snyder
