nt multicast
    Bill Nickless
    nickless at mcs.anl.gov
    Thu Jul 27 17:57:08 CDT 2000
-----BEGIN PGP SIGNED MESSAGE-----
There's a problem with your AG multicast tunnel.  First, I had shut down
your tunnel due to some problems here at Argonne and forgot to fix
it.  Second, now I can't get to your router at all.  Here's what a
traceroute says:
fire% traceroute 164.122.38.2
traceroute: Warning: Multiple interfaces found; using 140.221.9.181 @ hme0
traceroute to 164.122.38.2 (164.122.38.2), 30 hops max, 40 byte packets
  1  stardust-msfc-11 (140.221.11.251)  0.743 ms  0.635 ms  0.471 ms
  2  kiwi.anchor.anl.gov (140.221.20.97)  0.999 ms  0.686 ms  0.671 ms
  3  esanl2-anl.es.net (198.124.254.165)  1.228 ms  1.303 ms  0.877 ms
  4  dcconn1-atms.es.net (134.55.24.16)  18.003 ms  17.855 ms  17.986 ms
  5  192.41.177.249 (192.41.177.249)  19.649 ms  28.594 ms  18.926 ms
  6  112.at-1-0-0.XR1.TCO1.ALTER.NET (146.188.160.82)  19.148 ms  19.466
ms  20.453 ms
  7  193.ATM11-0-0.BR1.TCO1.ALTER.NET (146.188.160.73)  20.619 ms  19.795
ms  20.014 ms
  8  s6-0-0.t200-1.Reston.t3.ans.net (207.25.133.9)  78.135 ms  197.949
ms  200.038 ms
  9  f4-1-0.t200-5.Reston.t3.ans.net (140.223.60.240)  20.646 ms  20.562
ms  20.965 ms
10  s3-0-0.t16-0.Los-Angeles.t3.ans.net (140.223.17.21)  84.318 ms  86.205
ms  82.564 ms
11  f0-0-0.c16-13.Los-Angeles.t3.ans.net (140.222.16.104)  91.525
ms  81.392 ms  82.510 ms
12  h1-0.c124-11.Honolulu.t3.ans.net (204.149.47.214)  131.978 ms  136.148
ms  132.872 ms
13  f0-1-0.cnss124.Honolulu.t3.ans.net (207.24.14.1)  131.465 ms  129.115
ms  130.440 ms
14  h0.enss3219.t3.ans.net (192.103.75.210)  134.585 ms  139.978 ms  134.688 ms
15  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  132.889
ms  136.506 ms  131.043 ms
16  h0.enss3219.t3.ans.net (192.103.75.210)  147.567 ms  212.649 ms  134.830 ms
17  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  144.534
ms  135.164 ms  132.884 ms
18  h0.enss3219.t3.ans.net (192.103.75.210)  140.860 ms  148.569 ms  222.392 ms
19  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  138.051
ms  142.391 ms  137.619 ms
20  h0.enss3219.t3.ans.net (192.103.75.210)  139.849 ms  145.432 ms  275.633 ms
21  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  140.323
ms  140.301 ms  148.138 ms
22  h0.enss3219.t3.ans.net (192.103.75.210)  146.542 ms  255.652 ms  151.453 ms
23  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  153.660
ms  143.163 ms  141.923 ms
24  h0.enss3219.t3.ans.net (192.103.75.210)  148.034 ms  311.547 ms  156.064 ms
25  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  143.344
ms  142.701 ms  147.420 ms
26  h0.enss3219.t3.ans.net (192.103.75.210)  148.297 ms  259.025 ms  148.986 ms
27  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  148.011
ms  145.499 ms  150.528 ms
28  h0.enss3219.t3.ans.net (192.103.75.210)  155.756 ms  281.513 ms  149.769 ms
29  s4-1-1.cnss124.Honolulu.t3.ans.net (192.103.75.209)  152.625
ms  151.129 ms  148.917 ms
30  h0.enss3219.t3.ans.net (192.103.75.210)  151.945 ms  381.247 ms  153.556 ms
Finally, it would be a great deal of help if you could run your IP
Multicast Beacon on your AG node Linux box at all times.  That way we could
debug and test connectivity independent of whether you have someone there
at the time.
At 12:41 PM 7/27/2000 -1000, Jeff Ramacher wrote:
>Does anyone know how to add/delete multicast routes under nt?  The
>normal 'route add' or 'route delete' commands fail.  A 224.0.0.0 route
>exists for each of my NICs (2 of them), but I want multicast traffic to
>go through only one interface.  Moreover, does it matter?
>Or, has anyone successfully dual-homed an nt machine on the ag?  I'm
>trying to do this with my office pc, which I just installed a second NIC
>into (to get it onto the subnet with AG multicast tunnel).  I can ping
>the AG router, but nothing shows up in vic.  I also haven't figured out
>yet if vic can select a specific interface.
>Any thoughts/insights appreciated  - aloha -
>Jeff Ramacher (jeffr at mhpcc.edu)                | (808) 879-5077, x264
>Maui High Performance Computing Center (MHPCC) | fax (808) 879-5018
>                                                | http://www.mhpcc.edu
Bill Nickless    http://www.mcs.anl.gov/people/nickless      +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7     nickless at mcs.anl.gov
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 6.5.3 for non-commercial use <http://www.pgp.com>
iQCVAwUBOYC+Q6wgm7ipJDXBAQFHwwP+I9bxhjaLNr3Sh131mXPxTLg49vnC5pyr
v0m5APByDgHfcwCs8NxMp/zhMXwjO2R8VGAi43HOb4KTUFo7BWRXgCSUo8iV4i6N
wtUI9uCRjj3jPzrMqTfYMIrNhRqaI5GvZ4FzndINC7lpNLyVSA4wXkKJg1ed7lMP
LyKqSvIe3xk=
=YCvb
-----END PGP SIGNATURE-----
