chatq cruise 7-24-00
Jim Farrar
farrar at ncsa.uiuc.edu
Mon Jul 24 08:08:07 CDT 2000
There is already a meeting scheduled in Lucky Labrador for something else,
beginning at 12:30 CST that will still be going on at that time. You need
to pick another room.
At 11:31 PM 7/23/00 -0500, Michael Grobe wrote:
>Greetings, Chautauqua Cruisers:
>On monday 7-24-00, we hope to:
> 1) test yet another telco backchannel option, in search of
> the perfect telco bridge provider,
> 2) test Cisco's IPTV viewer/server software for use in
> displaying MPEG animations over multicast, and
> 3) test a new VNC server.
>We will probably have to extend the normal cruising time from
>1:30 to 3:00 or so, to get all this in.
>We will have the telco backchannel numbers for you on the Lucky
>Labrador meeting point on the Waterfall Glenn MUD.
> !!! Remember we will meet in the "Lucky Labrador" meeting point rather
> than the "Access Grid hangout" on the MUD. !!!
>The IPTV viewer software is available for download through the University
>of Oregon Video Lab and the Internet2 Networks Multicast Trial program at
> http://netaid.uoregon.edu/
>The VNC server address will also be distributed over the MUD.
>The new VNC server will (we hope) be running on a box configured to
>serve as a replacement for any one of the main node boxes. That is, it
>includes dual 650MHz CPUs (440GX chipset, 256MB SDRAM), 2 WinTV Model
>401 cards, a dual-headed Matrox G400, a single-headed Matrox G200,
>and a PCI 128. The idea is to use it in case of complete failure
>of any one major node computer (display, video capture, or audio).
>(Thanks to Doug Johnson for the inspiration.) In the case of EITHER
>display system or video capture system failure, we should be able to
>limp along running either 2 projectors (in place of 3) or 2 cameras
>(in place of 4). If both systems fail, I suppose we can run 2 projectors
>and 1 camera within Win2k.
>:michael grobe
>assistant director
>academic computing services
>the unversity of kansas
>(785) 218-5252
>grobe at ukans.edu
>http://www.cc.ukans.edu/~grobe
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20000724/ece2d6ec/attachment.htm>
