Projector Connections
Jonas Talandis
jonast at evl.uic.edu
Fri Dec 1 09:49:44 CST 2000
Use broadcast spec VGA cables, plenum rated if you plan to run them above
ceiling tile. They cost more but the signal quality is worth it. Markertek
is a good source. www.markertek.com
At 02:16 PM 11/30/00 , Don Morton wrote:
>Wow, sure are lots of little details to worry about! :)
>As we get our electrical and network connections in, it
>dawns me that I need to understand exactly what cables are
>used with the projectors, so we can run them neatly.
>I have the Epson 710C's. Am I correct in assuming that the
>only cables I'm going to need are the serial DB15 and power?
>Other cables come with the projector - mouse, audio - I see
>no reason to run those. As it stands, I'm going to need to
>get myself longer serial cables.
>As the equipment comes in, and the facilities get closer,
>prepare yourselves for many trivial questions :)
>Thanks,
>Don
> Don Morton http://www.cs.umt.edu/u/morton/
> Department of Computer Science The University of Montana
> Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
Jonas Talandis
Electronic Visualization Laboratory
University of Illinois at Chicago
voice: +1-312-996-3002
fax: +1-312-413-7585
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20001201/241b331f/attachment.htm>
