Russ is da man (conf call switchover)
Robert Olson
olson at mcs.anl.gov
Fri Apr 28 13:23:02 CDT 2000
>Are these plans compatible with Linux on the control machine?
They will most likely require Linux on the control machine.
>On the other hand, are you saying that we should hold off on the
>Linux/VMWare/W98 solution, on the control machine, until these plans come
>to fruition?
Yup. The plan for the control machine is still as originally specified:
Windows 98 to run the echo canceller software. If folks want to run it via
VMware on Linux on the control machine, they are free to, but it is their
responsibility to make sure it works properly in that configuration.
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20000428/5040f850/attachment.htm>
